Problem!!!
Hello
I have got tomtom one, recently it was working fine shine in my car but it kind of crashed i saw the screen crashed and then after that it doesn't turn on.
i have reseted it too, and also tried charging it up, well, it was charged up when it went off as i was driving....
Does it mean that i have lost the tomtom? :( or any ideas?
Are you using an SD card in your device? Have you tried to boot without the SD card installed? Have you tried holding in the reset buttong and turning on power at the SAME time?
If not, you may want to read another user's experience and the hardware failure he found: http://tomtomforums.com/showthread.php?t=11669
garoutte07
