- Joined
- Nov 1, 2008
- Messages
- 4
I drive a truck doing multidrop deliveries so a sat-nav is a must. I recently got a new Tomtom One (3rd Edition) to replace an old Medion one I had. I was loving using it, it does so much more than my old one. It is perfect for my job. That is, until today when it decided to die on me right after my first drop
The unit had been on. Arrived at destination. Made the drop and jumped back into the cab. The screen was now white. No map, no symbols, nothing. Just a white screen. The power button didn't do anything so I pressed the reset with the end of a pen. That started it up. I got the tomtom start screen and the tomtom sound. The disc loading bar ran across the bottom of the screen. It then displayed the tomtom start screen again, it then flicks to a very slightly brighter display. That's all that it does. The only way to power it off is with the reset button.
When I connect it to my PC I can use the unit no problem at all. All my favorites are there. I can plan a route. Everything works on the monitor, but the unit just displays the tomtom screen.
Arghhhhhhhhhhhh!! Any ideas? Please
