Maximum Memory Size for Micro SD Card?
South Wales (In the UK)
GO 910
Hi Guys,
Can anyone tell me please what the Maximum Memory Size Micro SD Card is that can be used in a TomTom GO750 Live TRUCK version, as I am about to get this model in a couple of days time.
Searching the TomTom 'Official Website' has produced no results and while I have seen both 2Gb & 4Gb mentioned in a couple of Model Spreadsheets it seems from topics in this Forum that you can quite happily use much bigger sizes which work.
Any help is appreciated
Suspect that a 32 gb sdhc card would work but that is overkill. Probably an 8 gb sdhc card, the faster the speed the better (class 6+) and a well known brand (like SanDisk, Kingston, etc.)
Hi dhn!
Thanks. I don't think I would make use of a 32Gb, so will go for the 8Gb while Kingston 6+ are being offered at low prices on eBay.
dfoss
