Because the newer maps are too big to fit on your 2GB unit. It's not a matter of 'want', in this case.But...why do I want to change to a zoned map?
OK. Just delete it. The objective was (and still is) to have no map at all on your unit to see what Home offers to you when you ask it to "Update" your unit. Home can be a little easier for reinstallation than the manual process of bringing it from your manual backup, and I'd like to try to get Home involved in both processes if possible.If I have made the total folder backup, why need to move the map off the unit onto PC (which takes quite a long time). I already have the backup (including the map), so why not just delete the map off the unit?
Which is precisely why I had you make that initial manual backup. Worst case, we'll put your 'current' map back on from that, whatever it is .. but I'm not moving another inch until I know which one it was!I was also surprised that it was the only one shown to me as available on the computer since I had USA on the device at the start of all this, so was surprised it did not show as an available map in the computer.
