How to replace battery in TT one 130?
I'm bought a refurb 130 from Comp USA a few months ago....I know, it was a bad idea. After using it only two times the battery went dead and I can't find out how to replace it. I ordered a battery that is supposed to be a direct replacement, but it didn't come with any instructions. Most of the other models apparently have screws on the back cover, but the 130 doesn't? It looks like it has a snap together housing, but before I started prying on it I thought I'd try this forum. Anyone have any ideas?
take off the front face panel (just pry carefully), then you will see four T5 type screws. done.
Colvic
