Help with TOMTOM LE
Discussion in 'TomTom Color Schemes' started by dawgrif, Nov 30, 2007.
  1. dawgrif
    dawgrif
    Nov 26, 2007
    5
    Southwest Virginia
    TomTom Model(s):
    Tomtom One LE
    Can I change these on a TomTom One LE. I cannot find the color scheme folder.
    #1
    1. Advertisements
  2. Spazmo
    Spazmo
    Nov 29, 2007
    36
    All you need to do is create a folder on your TomTom device called "schemes" (make sure the 's' is on the end of schemes) and place the .clr in that folder.
    Edit:
    Once you have put the .CLR files in the correct folder, unplug your TT from the computer and then go to your menu, find "Change Preferences" then find "Change map colors". You will then need to go to Advanced and find the "Plug-In Scheme" option. Select that one and a list will come up. Select an item in the list to be your DAYTIME SCHEME. You will then be brought back to the original screen. Go to Advanced again and find Plug In Scheme again. This will bring up the same list, but selecting one this time will choose your NIGHT TIME SCHEME.
    I hope this helps.
    Spazmo, Nov 30, 2007
    #2
    1 person likes this.
    1. Advertisements
  3. dawgrif
    dawgrif
    Nov 26, 2007
    5
    Southwest Virginia
    TomTom Model(s):
    Tomtom One LE
    Thanks. I had them on there but could not figure out how to use them until now.
    #3
  4. Spazmo
    Spazmo
    Nov 29, 2007
    36
    No problem....now to try to figure out how to change that damn blue arrow...
    #4
    1. Advertisements
It takes just 2 minutes to sign up (and it's free!). Just click the sign up button to choose a username and then you can ask your own questions on the forum.
  1. cputrdoc
    0
    1,818
    cputrdoc
    Sep 23, 2008
  2. TomTom125NA
    6
    1,323
    TomTom125NA
    Feb 28, 2009
  3. shawinglasgow
    2
    5,269
  4. pengjn
    3
    2,905
    mikealder
    Jun 15, 2011
  5. msf1344
    TomTom XL IQ freeze on tomtom logo screen
    msf1344, Feb 6, 2012, in forum: Technical Support
    20
    4,234
Loading...
