Battery Problems or Other Problems?
TomTom Go 730
I've had the Go730 for a couple of weeks now and I'm noticing some problems. Often I keep it in the USB mount but off. When I keep it in my carrying case, it generally starts up strangely. The screens keep switching back and forth as though I were touching the screen. I'm wondering if the battery could be going down with it off.
I would like to leave it off in the carrying case, turn it on, and then check the battery charge to see if it is very low. How do I check out the battery time remaining?
tap the lower right corner of the screen - it should com up with the relative battery level near the top right.
LizBrian
